11-22-2024
06:28 PM
11-22-2024
07:56 PM
computergeek541
11-22-2024 06:36 PM
Your old SIM will continue to work from 90 minutes to 2 hours to complete the porting. Once you see SOS on the top of your phone. Power off your phone and swap to the PM SIM and power back on.
11-22-2024 06:32 PM
hi @Beelezebub
you can put in the sim card now and test outbound calls first
if you ported the number, make sure you replied the porting authorization text before you put PM sim card), then reboot your phone ever 15 mins and test inbound calls
11-22-2024 06:30 PM - edited 11-22-2024 06:34 PM
@Beelezebub After you replied yes to the confirmation text from old provider and the old providers sim stops working . Then it’s time to test the PM SIM card for out going and incomming calls text and data .
adding you get instructions saying it will tell you when to put it in the phone but those steps are backwards I wrote thread in this issue long time ago it only tells you to put SIM card in after you do and confirm full access for the first time so strange check it out
Activation steps backwards @Beelezebub
Some activation steps are backwards - Community
11-22-2024 06:30 PM
if you ported in the number, you can wait until your current mobile provider sim card no longer works, or see SOS, then put in PM sim card
