Sim won't connect to phone after i did a system update
Nathaniel11
So I do a system update on my phone which is a Zenfone 3. Network doesn't connect after. I wasn't worried at first until I noticed I would get bars for about 5 seconds every 2 minutes or so. I noticed the apn was gone so I tried to re-enter it. I would hit save but it would never save. Then I open it again after trying to create lots of different apns and they all appear at once. Even when one was selected it still didn't work. Not sure if this is a Sim card issue or my phone. Any help is much appreciated!
2 REPLIES 2
Nathaniel11
Thank you!!
NDesai
This is a known issue on Zenphones upgraded to 8.1. Here are previously reported threads that might help you resolve your issue:
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Connectivity-issues-after-upgrade-to-...
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Calls-work-No-Data-Cannot-edit-add-AP...
