Sim problem
TR22
@TR22  - is it activated? If not you can activate the SIM card here: https://publicmobile.ca/en/on/portal/activation
DDM69
No Sim problem…
@TR22
Can you give us more detail of your issue?
Are you porting over from another carrier or picked a new number?
It is like saying: my car won’t start…it the the battery? No gas? Alternator? 🤷‍♀️🤷‍♂️
hairbag1
What is the problem with sim that you experiencing ?
edit'd...
20 minutes later haven't heard from you. If sim is acting up, try it in a different unlocked phone. We really need more info for better help though.
Metal1967
@TR22  You’ll have to elaborate to get some help..
