10-04-2022 04:31 PM
My sim card is active but not working in any of my cell phones I have.
10-04-2022 06:35 PM
Did you old number over to PM or picked a new number?
What phone do you have?
Is it unlocked?
10-04-2022 04:57 PM
@Tarawoodin then you will have to open ticket with PM support as I suggested above
(FYI, everyone here is just PM customer like you, just that we are trying to help. But in your case, a ticket is required to engage support)
10-04-2022 04:55 PM
As i me I mentioned. The SIM Is active. I get a ‘no sim’ on my phones. We tried 3 different cell phone. Please fix my sim card
10-04-2022 04:50 PM
Did you just join today?
What message you are getting? No Sim ? SIM not provisioned? No Network?
If you just joined, it could be that the sim card wasn't provsioned properly. It is an easy fix for PM support, you will just need to submit a ticket
If you are existing customer and confirmed that your account is active , you can also open a ticket for PM to check:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
10-04-2022 04:38 PM
Can you login to your account? Can you try it in private mode? Maybe the account is not active.
