10-08-2023 11:15 AM
10-08-2023 01:54 PM
I am brand new to Public, but have a suggestion that may work. I had the same issue with another provider with the same phone I'm using and initially was intermittent, then became constant. When I took out the SIM, I shot a few quick sprays of compressed air, worked no issue after. Some dust and stuff came out and I believe that blocked the contact
10-08-2023 11:35 AM
Try resetting the Network Reset setting on your phone.
10-08-2023 11:29 AM
@Aminat even you didn't change your phone, but for peace of mind, please check if your phone is clean
10-08-2023 11:22 AM - edited 10-08-2023 11:37 AM
Go into your settings and try resetting your network settings and then reboot your device.
Also do you have another device to test the SIM card in?
10-08-2023 11:18 AM
I have already tried removing sim and reinstalling also I haven’t changed my phone recently
10-08-2023 11:16 AM
