10-07-2020 08:02 AM - edited 01-05-2022 03:40 PM
Dear community,
I activated a new Sim while transferring my virgin mobile prepaid number to public mobile yesterday.
My account was successfully created and it shows my old phone number (as I wanted) on self serve. My credit card was also charged for the plan.
But I am unable to use the Sim even after 12 hours. I am on Android. The settings show unknown Sim. Do I need to wait more?
Joining Public
10-07-2020 11:09 PM
10-07-2020 08:51 AM
Thank you! Ìt worked after reinserting the sim and rebooting the phone. I can use my sim now.
10-07-2020 08:51 AM
You could try network reset also. Toggle airplane mode on, then off.
It does not look like stuck port issue. With incomplete port, you should be able to dial out and text out. Not be able to receive any calls or texts. Is it possible that your phone is locked to another carrier?
If these suggestions don't work, then likely account provision issue and you will need to contact moderator as described above.
10-07-2020 08:38 AM
@durraniu wrote:Dear community,
Hello @durraniu ,
Remove, and reinsert your SIM; Reboot your phone with your PM SIM card in it.
Do you have any services after doing this?
10-07-2020 08:10 AM - edited 10-07-2020 08:14 AM
Try putting your Virgin sim back in your phone to see if it works. If it does then use it until your port is complete. Once the port is finalized then your Virgin account will be closed.
If you still need further assistance then submit a ticket to a moderator.
To complete your port-in request, please open our chatbot via this link and type in “port request” to be put in touch with a Moderator.
