Sim card
Adam65
Entered a sim cards number.says not valid
2 REPLIES 2
Chalupa_Batman
If you're getting an invalid SIM card number, good chance it's already been used. If it's new, then you may be incorrectly entering the number. I think there's a barcode you can scan to make it easier. If it's an older SIM card, sadly they aren't reusable. If you need a new SIM card, here's how.
To get a new SIM card the fastest routes are these.
https://www.publicmobile.ca/en/bc/pick-up-SIM - Find a local store in your area.
Amazon - Here you can get it cheaper and maybe a few days wait $4.99
Or find a Mobile Klinik near you. https://mobileklinik.ca/stores/
hairbag1
@Adam65
is it a brand new sim...must be new and never used before.
