Sim card swap
Balveersidhu
I am not able to change my sim card as i lost it and i don't have my public account. How can i change my sim card as they are sending me 6 digit code on my number.
darlicious
@Balveersidhu
Did the retailer where you activated give you a print out of your activation details? Do you have the rest of the credit card sized tricut sim card that the nano sim was snapped out of? Did you get the welcome email from pm? Did pm text you your 4 digit account pin # on 611? Did you register for autopay when you activated? Did you put the sim card in your phone once it was activated and you had service? Do you still have the phone? These all contain details of your account info you will need to verify your account in order to get the CSA to swap out your sim card. Gather as much as this info that you can so you can satisfy the extra verification questions from the CSA.
@Balveersidhu
Who activated the old SIM?
Did you setup your account after it was activated?
The only option is for you to contact a CS_Agent to help you out but they will need all your security credentials for them to access your account.
@Balveersidhu   Yes, you need to login to MY Account to request Change SIM card.
If you never setup a Self-Serve My Account yet, you will  need PM Support to help with the SIM swap.
Please open ticket with PM Support using direct message:
**Monitor your Community inbox, envelope on the top right, after ticket is opened.  CS Agent will reply and work with you  via messaging there
