Sim card not working
grimsby
phone says no sim I am logged in, my account is active and new.  Wifes sim card works in my phone (public) my card won't work in hers or mine.  Is it a bad card
10 REPLIES 10
maxmobile
contact moderator
my number is xxxxxxxxxxxxx
account number xxxxxxxxxxxxxxxxxxxxxx
Name xxxxxxxxxxxx
$50 plan
I bought new sim yesterday but it is not working
edited by computergeek541: account information removed
@nikolariet wrote:
How to add $1 to which account ?My problem is when I try to active my sim card, system showing "invalid sim card"
 @nikolariet
It would be organized if you kept working on your other thread.
You're not at the point where this would be helpful to you so disregard this thread. Good of you to be looking around though.
nikolariet
grimsby
Thanks it was the SIM card that was defective
hss
The Sim could be damaged. Make sure your phone is not locked to a carrier or blacklisted on telus. If your Wife too got Public Mobile then it might not be the case.
Try cheching your network settings on your phone as well and make sure that it is set to automatic.
grimsby
No it won't work for calls or texts
@cellphoneuser1 wrote:
Does it also say no sim in her phone too or you just can't make calls, send texts, or use data?
grimsby
Thanks, I tried that still not working.
cellphoneuser1
popping
@grimsby
While you are waiting for moderator to work on your account, add $1 to your account may trigger PM server to provusion your account again.  Good luck.
Dunkman
@grimsby
It might be a bad SIM, but SIM card are not defective often.
Account might not have been provisioned properly.
I would recommend contacting moderator first:
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator.  Type: Contact moderator. Follow the prompts to submit ticket.
[Actual solution among suggestions highlighted  .......  Luddite]
