11-29-2018 10:47 PM - edited 01-05-2022 02:38 AM
i have a asus zenfone max plus i just got a couple weeks ago and i have been on public mobile since i got the phone now the phone updated to android 8.1 from 7 now i have no connection at all and if i put the public mobile sim card in my android 7 phone and it works fine what can i do? @CS_Agent
11-30-2018 12:02 AM
@farmerjosh3 wrote:do you know how i can revert to android 7 that this phone came with because the sim worked fine with android 7
I don't think you can revert backwards on an OS update. If you could, then Asus did a bad job. Rolling back updates is the oldest trick in the book to exploit security holes. I find it hard to believe that an OS update can make a phone lose compatibility with a cell network. Failing to install and bootlooping is one thing, but completing the update and then breaking the phone seems really odd.
At this point, I suggest giving lineage OS a try. There is nothing to lose If the zenfone in question is model X00TD, then there is official lineage support. Version 15.1 is android 8.1.
https://download.lineageos.org/X00TD
11-29-2018 11:55 PM
This is one version. I'm not endorsing it or anything. Heck I don't even have an Android phone. It looks pretty complicated. Sorta like LineageOS maybe.
Maybe only a little more complicated than that redflagdeals link instructions.
How'd it go with the lost/stolen?
11-29-2018 11:29 PM
11-29-2018 11:24 PM
oh okay maybe
11-29-2018 11:23 PM
About LineageOS...it might be that your phone isn't compatible.
11-29-2018 11:22 PM
ok ill try that first
11-29-2018 11:20 PM
@farmerjosh3 wrote:i contacted asus support and they got me to factory reset it and it still wasnt fixed
Right. It's a known 8.1 problem.
Just for giggles:
Try the lost/stolen feature.
Log in to self-serve. Plan & Add-Ons from top menu. Lost/Stolen Phone from next menu. Suspend Service button. Log out. Wait a few minutes. Log back in and back to Lost/Stolen Phone and Resume Service this time. Log out. Restart phone.
See what happens.
11-29-2018 11:18 PM
11-29-2018 11:14 PM
@farmerjosh3 wrote:what does that software do anyways?
The redflagdeals solution that RobertQc also linked to was the other more technical possibility.
But again, have you restarted the phone? Maybe also the lost/stolen trick might fix those bars.
11-29-2018 11:13 PM
11-29-2018 11:11 PM
yeah so after the update happend then all my signal bars went away then it flashes on and off and i can't do anything
11-29-2018 11:10 PM - edited 11-30-2018 01:21 AM
@farmerjosh3 wrote:ok thanks i was wanting to go back to android 7 but they said i can't when i contacted asus tech
@farmerjosh3You can, most definitly downgrade. (By doing a clean and fresh install of a v7 rom)
I would however, if it was me- install LineageOS instead. I refuse to buy a phone that does not support LineageOS.
If you have some free time and feel up to it, do it here https://wiki.lineageos.org/devices/X00TD or https://forum.xda-developers.com/asus-zenfone-max/development/llineage-os-8-0-asus-zenfone-max-z010d...
Make sure to confirm your exact model and to follow the instructions to a T.
11-29-2018 11:08 PM
11-29-2018 11:02 PM
@farmerjosh3 wrote:oh okay i think ill go try a different company because i need my phone for work
Have you rebooted the phone?
Does voice work? Text? Data? Any? Some? Account active? Suspended?
Yes this a known issue for data things but one possible work around is to insert another SIM and set up the APN.
There is another possible rather more technical solution as well.
11-29-2018 11:00 PM - edited 11-29-2018 11:02 PM
@farmerjosh3 wrote:i have a asus zenfone max plus i just got a couple weeks ago and i have been on public mobile since i got the phone now the phone updated to android 8.1 from 7 now i have no connection at all and if i put the public mobile sim card in my android 7 phone and it works fine what can i do? @CS_Agent
@farmerjosh3This is common, if you don't feel like putting lineageOS on your max, or downgrading back to 7, read this https://forums.redflagdeals.com/solved-fido-apn-miui-10-cant-add-apn-2239645/#p30122708
@farmerjosh3 This is not public mobile, this is a problem that can happen across all carriers with 8.1
11-29-2018 10:59 PM
11-29-2018 10:51 PM
Looks like its an issue with the 8.1..other members have been experiencing the same issues
