Sim card not received
georgesq40
My wife ordered a sim card, order number 290788,but we have not received it. Can you check and send another?
JL9
Many have said it seems to be 3 weeks if not longer now. Going forward if you ever need a sim again you may want to go in store or order from a place like Canadian Cell Supplies as it is much quicker and you don't have to deal with the headache of such a big delay.
@georgesq40   Ordering SIM from PM online is a bit slow.  Usually it takes 2 to 3 weeks.
If you would like to double check the order status, please message PM Support directly with your order number:
here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
If you need it urgently for activation, you might want to activate in store.  Most stores will give out the SIM for free if you activate with them
iliketotalk
@georgesq40 hi we are customers like you sim cards can take up to2 weeks for delivery hang in there
