11-15-2024
10:58 PM
11-16-2024
01:30 AM
computergeek541
11-15-2024 11:12 PM
hi @AmazNelsons are you trying to activate new account or buying replacement?
if you subscribe new, remember to get a friend code and use the PM app to subscribe
if you are replacing, you can login My Account and change sim number on Profile page
11-15-2024 11:07 PM
Will get from the Koodo store across from my work tmr
11-15-2024 10:59 PM
hi @AmazNelsons
dont but sim from PM, it could take long to deliver
Buy a PM physical sim card form Telus or Koodo store or via Amazon:
Telus or Koodo store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
