Sim Card question
simpleman
Been with Public Mobile for about 6 years now. Yeah, it's an old sim card. 5G was unheard of back when I purchased this sim. If I move from my 4G plan to a 5G plan with Public Mobile (granted I need a 5G phone as well) do I need a new sim card or will in fact my present sim card allow me to access and take full advantage of the 5G data speed?
@simpleman
Just think of your old SIM as an account and everything is stored in the SIM.
If you change your plan (3G>4G>5G) it will change in your SIM.
hi @simpleman the same sim card will work with 5G plan.
and you don't really need a 5G phone.  The 5G plan is about speed.  you can have a 5G plan ,access the 4G LTE network and get a speed promised on the 5G plan, like 200+ mbps
Meow
SIM has nothing to do with speed (G). You can continue using existing one and switch to 4/5G at any time.
@simpleman  No you don’t need a new sim card for 5G plan , your current SIM card will do the trick
