Sim Card Trouble
ChadP
My phone loses its mobile data due to the Sim card not recognizing my phone number? can you help work this?
yeej
@ChadP , I had the same issue.  I turned Airplane mode to ON, waited 30 seconds, then turned Airplane mode to OFF.  My network was able to re-establish connection after that.  Good luck.
yeej
Same here.  No internet but still able to receive/send calls.
ChadP
try the above suggested items with no resolution, I have to go to Sim and reset it each time on my phones settings to get it working
hi @ChadP might not be your sim
there seems to be problem with Mobile data in some area. Try Reboot phone and click Reset network settings
if you need to submit ticket, you can use Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
