07-30-2023 02:28 PM
Bought a new e-sim and while i was activating it i tried to delete my old carrier account but accidentally deleted my esim. i went and bought a new one and am trying to switch the sim over, and now i cant get any texts to my number to confirm my full access so i cant get into my account to switch sim. please reset my 2fa so i can login via only email. tried all other was around. very angry
07-30-2023 02:48 PM
most definetly. this is all making my head hurt. contacting support now.
07-30-2023 02:46 PM
Jeez a whole thread of replies of misinterpretations. I avoid these kinds of questions because this new system is so stupid.
I think you need support to sort this out. At least some of the replies gave the support link.
07-30-2023 02:41 PM
bruh i literally said i just went out and bought the physical sim....... smh read please.....
07-30-2023 02:40 PM
@LiamFrench it is likely PM cannot provide you another eSIM if you have already installed but deleted it. You might have to go back to physical eSIM. Message support to confirm
07-30-2023 02:37 PM
i have not made 2 accounts. i made one and in the process accidentally deleted the esim. i just need access to my account to tranfer my new physical sim over. i have not activated the new sim.
07-30-2023 02:34 PM
@LiamFrench I should hav also mentioned. To sign in try tapping resend code a few times. . This should give you option to send code to email instead . If no luck please submit ticket with support
private message To CS_Agents click
VVVVV Link below VVVVV
07-30-2023 02:33 PM
i need to confirm full access to my account but cannot without a phone number
07-30-2023 02:33 PM
sounds like you have created two accounts in this process, but this is not the right way to go please message support to get this resolved:
07-30-2023 02:33 PM
i have no access to my account account of 2fa
07-30-2023 02:32 PM
omg.... i already did. i just went and bought a physical sim
07-30-2023 02:30 PM
@LiamFrench Sorry eSIM only for new activation . Not existing customers . Once deleted you need to go to physical SIM card . Try calling local telus Koodo store for availability. Then log into your my account and go to profile tap to SIM card swap the number
SIM SWAPPING profile tabs
Note only do this on lap top or computer/ not mobile device
