Signed up for $40 15 Gig and 4G but account shows it as $40 5 G
AGFair
I bought into Public Mobile's $40 15 Gig with 5G speed last week. My account is showing that my data is only 5 gig. Why is it not showing correctly.
AGFair
AGFair
I chose the 15G.
AGFair
I absolutely chose the 15 G plan. I have already submitted a ticket.
@AGFair - if this is a cache issue on your account, click the little arrow circle to see the most up to date information.
Hi @AGFair there are two $40 plans and I hope you didn't pick the wrong one
Login My account again using Incognito/private/secret mode to confirm
if you see 5GB still, you picked the wrong one and need to make a plan change on next renewal.
But maybe  check with CS agent and see if they can help
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
will13am
@AGFair , both plans that you have mentioned are available.  Are you sure you picked the $40/15GB plan.  The plan scrolling can be rather confusing to the eye.  Also, you need to access the self serve account using incognito mode to ensure that you are not viewing stale cached data.  Finally, if you did select the 5GB plan, it is simple enough to select the $40/15GB plan and future date the change on the next renewal.
