Signal network
Ed28
Im encountering no signal just on and off
can you help me how to fix it!
@Ed28
Did you try pausing the VPN and see if that helps?
Pavlozky
lower the curtain of the applications twice, there will appear the logo of on and off
@Ed28
what phone do you have? it could be just a network issue in your area
Try Reset Networks Settings on your phone.  And if you have around phone around, try the sim card there. This could force a sim reprovision and could resolve the problem
