Should my iphone 15’s esim be on or off?
Lizz4
hi @Lizz4
when you are in Europe, you can disable PM eSIM, but remember do not delete it
then when you are back in Canada, enable your PM eSIM back and disable other eSIM
Lizz4
They sre working while in Canada but when in Europe I was not able to add an additionsl esim. It was a Jetsim which stated that service eill start upon arrival at your destination
hi @Lizz4
are you using PM eSIM? if you are, the PM eSIM must be on (Turn on this line is enabled)
but all other eSIM from your other carriers should be off
hairbag1
@Lizz4
if your talk / text and data features are working as expected...just leave things as they are. If they not working...let us know.
