12-26-2021 07:21 PM - edited 01-04-2022 04:47 AM
Is there a way to quickly see how much data I have remaining without having to login to the self-service website? ie: a certain code I can type in or something like that?
12-26-2021 08:25 PM
Yes, it would be nice. But all these could be done easier with an App, but PM has no app and likely won't be one
12-26-2021 08:18 PM
A shortcode system would be a nice feature to have though, maybe they could be persuaded to add it in the future.
12-26-2021 08:13 PM
@Anonymous Thank you for your post. Helpful! I assumed 611 only gave the data add-on limit. I will go correct my post.
12-26-2021 08:09 PM - edited 12-26-2021 08:10 PM
@mig39 : The first reply is correct but incomplete. You'll need your 4 digit PIN to hear it. It will give you the remaining amount of all data buckets on hand as one number.
12-26-2021 07:56 PM
I would recommend resetting your devices data counter on the evening before each 30-day renewal.
This is easily done under your mobile data or cellular tabs on your device.
Then you'll know for the upcoming 30 day cycle how much data you have consumed.
This option requires no logging in to view any remaining data allotment.
12-26-2021 07:45 PM
While these apps are OK, they are not official from PM and you will find differences in what you see in app vs what it is on PM site.. Having said that, they might do the work for what you need.
12-26-2021 07:30 PM
@hTideGnow wrote:Hi @mig39 Yes, there are ways to check the data usage quick. With the support of app that can track 30 days cycle as PM uses 30 days
on iPhone: My Data Manager
on Android: Data Witness PM or Data Counter Widget
Check it, download one of them and it helps
Ah...yes. I was thinking of built-in data minder. You're right though....I'm sure there's an app for that !!! 😄
12-26-2021 07:30 PM - edited 12-26-2021 08:15 PM
@mig39 Unfortunately you would have to log into your account to see data usage. You can see if your phone allows you to set a 30 data usage counter so you don't have to log in.
Also a PM member made an android app years ago to check data usage via an app. Not sure how good it works or if it even still works as I never tried it. Link below.
https://play.google.com/store/apps/details?id=com.iwik.datawitnesspm
EDIT - Also dial 611 as per Z10USER4 post.
12-26-2021 07:28 PM
12-26-2021 07:26 PM - edited 12-26-2021 07:28 PM
@mig39 wrote:Is there a way to quickly see how much data I have remaining without having to login to the self-service website? ie: a certain code I can type in or something like that?
Nope, there isn't. You must log in to your account / My Data and Add-ons to view how much data you've used. If there's no mention of any data...you've used it all up until next renewal.
You will get a SMS text when you've reached 75% and 90% consumed.
Any More is Merrier data or other bonus data will get used when plan data is used up...if you have any, that is.
12-26-2021 07:23 PM - edited 12-26-2021 07:24 PM
*611
or sign in to Self-Serve, to review your account.
for more information about Managing Your Data Usage visit Here link to save your data...
and turn off background data, to save your data.
when your data limit used all, is will be off until next renewal cycle,
at public mobile 30 day Prepaid Service No fees extra charges,
