10-23-2019 04:04 PM - edited 01-05-2022 07:42 AM
At our company we use an email security company named Mimecast. When we log into their system they send us a text message for two-factor authentication. In Canada the short code number Mimecast uses is # 79013. These messages work fine with other telco carriers, however, with Public Mobile they failed to be delivered. How can we get #79013 on the Short Codes list?
Thanks,
Frank
10-23-2019 04:11 PM
Thanks,
Frank
Updating the shortcode list within the next few weeks, thanks for flagging.
For now you should use the full phone number as provided on here: https://www.txt.ca/en/current-short-code-programs/
10-23-2019 04:24 PM
I don't understand how we can use the full phone number? We don't have a choice in this matter. They are the ones that send us the text, not us to them. We only receive their text via 79013 for the authentication code. We don't text them. We urgently need this working as we use them for work purposes. Thanks for your help.
10-23-2019 05:13 PM
@fcandia PM does not do a good job supporting short codes.
Do not expect a quick resolution. Best to make alternative arrangements.
10-23-2019 05:53 PM
@fcandia Did you port your number from another provider? If yes, is it possible to setup your 2FA again to see if you can receive the initial signup text. In the past that is what I had to do to receive verification codes from other vendors.
