11-18-2016 02:39 PM - edited 01-05-2022 12:35 AM
Hello,
Just want to share my experience on porting from my Rogers account into PM. I see a lot of people having issue in this regard but my port in expereicne was quick and easy.
1. I activated PM sim with a new number.
2. After I made sure PM is working properly on my Iphone, I login to my account and go to change my number. I made sure that I did it in the night where I won't need to use my phone. So send in the request around 11pm and received confirmation text by 12:50 AM that port is completed.
So I know many people are not having the same experience but to minimize the down time, I suggest try doing it in the late evening or night so you won't get interupted.
01-24-2020 02:42 AM
@laivincent wrote:I just activated the PM sim card. I ported my Roger's account. The SIM was activated successfully. When can I start using the new PM SIM card?
Thanks
You start using the Public Mobile sim card immdiately. However, incoming text messages originating from a non-Telus customer and incoming calls (from anyone) won't work until after the phone number has been fully transfered.
01-23-2020 10:34 PM
Thanks
11-18-2016 06:25 PM
Will help me for when I port another number tonight. Thanks!
11-18-2016 04:13 PM
I wouldn't say mine was 100% smoothless but probably 95% smooth... port took about 30 minutes (when the text message came in saying it was done). I ported at activation.
11-18-2016 02:51 PM
Thanks for the positive post. I also came from Rogers and had a smooth transition as well without creating a temp number. The later time frame makes sense as well as servers will be less busy.
