11-23-2025 04:03 PM
Hi PUBLIC MOBILE HELP STAFF ,
Its been a very very frustrating experience using public mobile website Login webpage : I am on the website and under MY Account there are no options at all just black. I cleanup my caches, I changed the web browser , I changed my devices still NOTHING under My Account as options. I must update my payment ASAP.
11-23-2025 05:23 PM
11-23-2025 04:56 PM
may I suggest you download the Public Mobile app to your cell, then log in to your account > Payment tab..then scroll down to see Update Card Information.
11-23-2025 04:26 PM
Open ticket first and PM will reply. This is the only way to have your problem resolved
11-23-2025 04:23 PM
IF I do NOT hear from PB staff to solve my issue ASAP I intend to change to TELUS MOBILE.
11-23-2025 04:19 PM
I MUST talk to a Public mobile staff..I am able to get in MY ACCOUNT but no options are there to availble the webpage just loads nothing ...no options under MY ACCOUNT
11-23-2025 04:13 PM
So, you can login and just the My Account not showing anything?
Try using PM app as well
And ask PM to help if needed Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
11-23-2025 04:12 PM
Hello.
Since you can't properly log in, please use this link to reach a customer service rep.
