Friday - last edited Friday by computergeek541
hello, i setup an esim on iPad and activated it but now it is sending a 6 digit code to the phone number setup but I don't have a phone, it is only for the data. Is there a way to verify the ever safe account other way?
Friday
In that case you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
Friday
I did try that yet it won't give me the option. I did veryify the code with me email then it asks to verify the 6 digit code by text.
@RileyTB, you should be able to select "Didn't get the code" and then select to receive it by email
