blocked from purchasing esim
corinne234
we are trying to setup a new phone with the old phone number. had a physical sim on the old phone and are trying to purchase an esim for the new phone but we are blocked from purchasing the new esim because it says we have an esim already
1 REPLY 1
HI @corinne234
so, you installed the PM app on the new phone and tried to buy the new esim using the PM app on the new phone?
if so, you have done it correctly, but you will need PM agent to check and help
submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
