10-10-2025
01:20 PM
10-10-2025
02:38 PM
computergeek541
Hi. I am trying to set up my new IPhone 16 from my iPhone 6s and need a Public Mobile code to do it. Can you please send one to me?
10-10-2025 03:03 PM
iPhone 6s use nano sim, so, it is compatible and you just need to move it to the new phone
if you have trouble with it, check with local Apple store and they can help
10-10-2025 02:53 PM
It is saying the iPhone 6s sim is not compatible with the iPhone 16
10-10-2025 01:29 PM - edited 10-10-2025 01:30 PM
You should be able to set up new iPhone when it’s aside your old one. It’s pretty much automatic.
Do you have a physical SIM or an eSIM?
Why do you need a code?
10-10-2025 01:24 PM
you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email. You can also choose Send Voice Message can call yourself from your phone or another phone to get the code via voicemail.
if you cannot get the code, ask PM CS agent to help. Private message CS Agent at:
