Set up account
01-25-2023 07:26 PM - edited 01-25-2023 07:30 PM
01-25-2023 07:35 PM
@Teyauna if you activate manually online, you would have a My Account created already
But if activated in store from before, there is a change no My Account was created
Either way, please open ticket with M support and they will sort it out for you
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
01-25-2023 07:32 PM
Have you activated your Sim card?
01-25-2023 07:30 PM
Have you had service here since before last July? ie. did you sign up in a store? If so then you need to contact support through the chatbot(simon) link below.
If you signed after last summer then look in all your emails for the welcome email from when you signed up or other marketing and promo emails. That's the login id. Then you can use reset password.
01-25-2023 07:29 PM
Welcome to Public Mobile.
Can you please go to the little arrow on the right hand side of your post and edit out your phone number? Please and thank you. You don't want the whole world wide web to know your phone number.
01-25-2023 07:29 PM
@Teyauna Are you looking to just join PM and port your number? Start here,
Purchase a PM SIM and start here, Activate Your SIM Card Online | Public Mobile
