Service not working
Bebite
I activated my service, but I still cannot make or receive calls or text.  What do I need to do to make it work?
1 REPLY 1
@Bebite
first, make sure your old sim card with the old provider is removed (or if old provider is eSIM, disable it).  then Reboot phone and Reset Network settings
if that does not fix it, it could be a sim provisioning issue.  It is an easy fix for PM support, you just need to engage them by direct message
