SIM to eSIM
PhilG
I currently have a PM Account using a SIM card. I plan on buying a new phone that only has an eSIM. Can I transfer my PM plan from a SIM card to an eSIM and still keep my current plan. If so, how is it done.
thanks in advance…..
1 REPLY 1
@PhilG
yes, you can easily change over to eSIM and keep your current plan and your current phone number
To buy new eSIM, first, download the app on your new phone and login.  If you have problem with receiving 2FA code, click "Didn't Receive code" or "Resend code" and choose either Send email or Send voice message
Once logged in, Click Account from the bottom, then click Purchase SIM Card and select eSIM
