Service not working need refund
Prerna2471
Hello i buy esim on November 10 and not able to connect to network I tried the bar code in the email you guys send to activate esim but still not working so i need refund and i will get new physical sim @CS_Agent
7 REPLIES 7
@Prerna2471
what is the make and model of your phone? If it is an older phone, it is not eSIM compatible.
@Prerna2471 wrote:
Tried not working still
@Prerna2471 , I’m soo sorry. Most of the time that works in cases that the eSIM may have installed but didn’t activate.
Please send a private message to CS_Agent for help using the link that @SourDude1234 provided.
HI @Prerna2471
do you see the eSIM showing up (installed) on your Cellular screen on your Sim Manager?
(and you are on iPhone or Android?)
Prerna2471
SourDude1234
Hi @Prerna2471
Make sure eSIM is activated in your settings (different for each brand) and then if it still doesn't work, to contact CS agent, use the following link -
Make sure to monitor the envelope icon on the top right since that is where you will receive the response.
LitlLdy
@Prerna2471 , have you tried the steps below to activate your eSIM?
Reboot your phone.
In cellular settings make sure that “Turn On This Line “ (for iPhone ) is selected. (I am not positive where the setting is on a different phone to turn it on, possibly ‘Turn on your eSIM under Mobile Network’), reboot your phone. (You may need to reset network settings then reboot)
dust2dust
Did you view that email on another device and scan it on the phone? Did you turn on the esim?
