Service in USA
Commander2
Please advise if my current cellphone package will provide service when I travel to California, USA.
hairbag1
@Commander2
if you have a Canada/US plan it should be fine but for talk, you MUST have a cellphone that is on the Public Mobile whitelist for VoLTE recognized cellphones....otherwise talk will not work in US. Here's some info and a checker...
https://www.publicmobile.ca/en/get-help/articles/volte
hi @Commander2
What plan do you have?  If you have a plan that say Canada-US (or Canada-US-Mex), then you can use your service in California.  Just make sure you turn on Mobile data roaming and make sure it connects to T-Mobile or AT&T or Verizon
slusagm
depends what plan you have.  If you have a plan that say Canada/US or Canada/US/Mexico, then Yes, you can use it anywhere in US.
