Service down?
melissajoseph
My phone says SOS and my service won’t work. Is there an outage?
pmbc
@melissajoseph it sounds like you have an iPhone. SOS may appear if you don't have a cell signal but iPhone still allows emergency calls.  Are you in a building that's blocking celluar signals?
These articles may be useful,
If you see No Service, Searching, or SOS on your iPhone or iPad - Apple Support
How to Fix “SOS Only” on an iPhone (howtogeek.com)
darlicious
@melissajoseph
Did you purchase your device brand new? If not check your phone's IMEI# below....
https://www.devicecheck.ca/check-status-device-canada/
You can find the IMEI# by going to "About Phone" in your Settings or by dialing *#06# on your phone.
@melissajoseph   possibly
First, login to My Account using Incognito mode to confirm your account status is Active
Try to reboot the phone
Try to reseat the sim card (Power down the phone, take sim card out for a minute, then put it back in and power up)
Try changing the preferred network type to 3G Only
Try the PM sim in another phone if possible
and try to use the phone in another area
Try to use it on another phone
Although you probably already tried, service can sometimes be restored with a restart of the device.  That can speed up to the reconnection to the network in the case the network did was down momentarily.
@melissajoseph
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
Try one or more of the below may help with that message or finicky things:
  • restart your phone
  • toggle into and out of airplane mode
  • perform a Reset of the device's Network Settings
  • remove and reinsert your SIM card
  • Can you try your SIM in another device to rule out the device?
LoveNature
@melissajoseph
Check the status of   Service Status  outages.
