08-30-2022 10:05 PM
08-31-2022 06:26 PM
Maybe a week
08-31-2022 06:26 PM
Funny thing is it’s intermittent if it were down and stayed down I’d agreed
08-31-2022 10:25 AM
HI @genioveva You mentioned every night, how many nights have that been?
08-31-2022 10:22 AM
Try toggling airplane mode on/off.
Go thru all of your settings. It sounds like a settings issue in your phone.
08-31-2022 06:44 AM
Data keeps on working the problem Is only talk and text
08-31-2022 02:57 AM - edited 08-31-2022 02:57 AM
Do you have access to mobile data at night or do you have access to Wi-Fi? If your mobile data is unaffected then your text should not be affected either as text will work on both the 3G and the 4G LTE networks.
08-31-2022 12:30 AM
Not currently and the interruption is on and off throughout the night time
08-30-2022 10:21 PM
@genioveva , by chance do you have some sort of timed do not disturb setting that is interfering with talk and text?
08-30-2022 10:09 PM
contact PM support team by private message CS_Agent to check your account.
Check the status of service outages if found something then reporting in same site.
also check Cellular Towers Map Telus or Bell.
08-30-2022 10:07 PM
@genioveva Every night?
Where you are? city and province? and what phone do you have? brand and model?
did you try to reboot every time it has problem?
did you reseat the sim card (power down first, take sim card out for a minute before you put it back and power up)
Also you have another phone to test? Try to put your sim card in another phone and see if it works
08-30-2022 10:07 PM
Every night @genioveva ?! But, you have all the services the rest of the day?
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
Perhaps these are workings of overnight services to towers in your area. How long has it been like this?
