09-22-2023 10:13 AM
I need help from a service agent but I can’t figure out how to contact them. Can someone help me with this please? @CS_Agent
09-22-2023 10:53 AM
This is exactly why asking for the problem works better initially and then we can direct you to support when needed once we see the problem.
09-22-2023 10:37 AM
@Haylss Sorry once voicemail is deleted there’s no way to recover it . It’s gone for good no work arounds sorry .
09-22-2023 10:34 AM
Thanks everyone for the replies. I’m trying to recover a voicemail that was accidentally deleted. My phone is not backed up so I’m unable to retrieve it that way. Calling into my voicemail and pressing 19 is also not working. Any other suggestions?
09-22-2023 10:24 AM
the PM Community Forum members are your first line to get help for most of your problems. Account related issues need the CSA help, otherwise we can usually help before they can. While you wait for the CSA to get back to you, give us a brief description of the issue and I bet we can get it sorted for you or direct you to the right resourse.
09-22-2023 10:15 AM
@Haylss Here’s how to get support
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-22-2023 10:14 AM - edited 09-22-2023 10:14 AM
To submit a ticket with CS agent, click on the link below.
Can you describe the issue that you are having?
