08-06-2023 04:59 PM
Did I seriously give up my old network to join this dumb ? 3 days trying to get into my account you’re sending codes to a number that’s 30years old …
no live chat no phone number
10-24-2023 04:51 PM
HI @tomkw1975
wait an hour and try again using Incognito/Private/Secret mode on your browser
you can also get the service back first by buying voucher. Get one from Shoppers drug mart and then load the voucher using *611
10-24-2023 04:26 PM
I would like to know why i can’t update my payment option with mt new credit card . I’ve tried several times
08-07-2023 07:41 AM
I have a similar problem and getting the same level of help.
08-06-2023 05:35 PM
Thanks Nancy drew … 🤦🏼♂️
08-06-2023 05:33 PM
I’ve done it on my laptop and it’s doing the same thing. I even added my phone number and they are still sending to my old number
08-06-2023 05:23 PM
I does not give me the didn’t get the code ? Only resend code . And there’s no option to pick when to send
08-06-2023 05:08 PM
08-06-2023 05:08 PM
To confirm full access it sends the code to an old number
08-06-2023 05:07 PM
How to receive 2FA code via Public Mobile Phone app
Click on the Didn’t get the code? Before you do though, check the box on This is a trusted device so you never have to be asked for the 2 step again on the phone.
The next window that comes up is this.
You can choose either Send Email which will go to the email you registered with or Send Voice Message meaning it will call your number and ask you to push buttons.
08-06-2023 05:07 PM
After I get out in the 6 digit email code it takes me to this page
08-06-2023 05:04 PM
My phone
08-06-2023 05:03 PM
Are you trying to do this via your computer or app on the phone?
08-06-2023 05:03 PM
It sends to my email then to get full access because it says unrecognized devices it sends a code to an old number
08-06-2023 05:01 PM
@tomkw1975 Try tapping resend code a few times you should get option to send code to email instead . If no luck please submit ticket with support to help
private message To CS_Agents click
VVVVV Link below VVVVV
