Sending pictures
01-20-2024 08:45 PM
01-20-2024 09:33 PM
Clear your messaging apps cache then reboot your phone. Try again. Report back your results.
01-20-2024 09:04 PM
thank you that was going to be next step
thanks for all the suggestions/ help
01-20-2024 08:57 PM
@Yvonne5 Can ask support to refresh your account and see if that helps or maybe they have some other suggestions
send a private message To CS_Agents
01-20-2024 08:51 PM
Yes Data is also on
tried everything
01-20-2024 08:48 PM
@Yvonne5 Do you have cellular data turned on ?
