05-01-2022 02:54 PM
Hi there, I cannot access my account. I tried answering the security question but it seems to be incorrect. Please help!
Brent
05-01-2022 02:56 PM - edited 05-01-2022 02:56 PM
@brentjefkins You'll need to ask customer support for a password reset. Submit a ticket via chatbot here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Or try sending a private message to CS_Agent if unable to submit a ticket here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
05-01-2022 02:55 PM
@brentjefkins if you getting self reset the password, please open ticket with PM Support and have them to reset it for you:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
