08-18-2018 11:48 AM - edited 01-05-2022 05:25 AM
cannot get my sim to connect to network, yet my account says active. Ive used this phone through other carriers so i know its unlocked. there really should be a better way of getting a hold of someone, this is brutal
08-20-2018 12:14 AM - edited 08-20-2018 12:18 PM
@stonechucker wrote:
What is your device? Many of us will assist you if you can answer our questions.
@stonechucker yeah @Luddite asked yesterday too. Still waiting on that info. $10 bet it's an overseas model that doesn't support the requried 850MHz + 1900MHz 3G frequencies!
08-19-2018 08:11 AM
Is your device locked to a non Telus carrier, or is it not compatible with the technology that is used on the shared Telus and Bell network?
08-18-2018 06:17 PM - edited 08-18-2018 06:18 PM
@RJW90 wrote:cannot get my sim to connect to network, yet my account says active. Ive used this phone through other carriers so i know its unlocked. there really should be a better way of getting a hold of someone, this is brutal
Unregistered sim card (some Blackberries would say this on the home screen) or Not Registered on Network/Cannot Connect to Select Network or similar wording when selecting the network ususally means that you have selected a network that your sim card/service isn't allowed to connect to or that the the sim card was never activated (or was activated before and cancelled).
Is the network not registered message showing up after doing a manual network scan and you are selecting the appropriate Public Mobile network choice?
08-18-2018 12:00 PM
just a little inconvient sometimes
08-18-2018 11:56 AM
I get it, for what we pay im not expecting stores to pop up everywhere.
08-18-2018 11:52 AM
What is make/model of your phone? It may be incompatible with PM's network.
08-18-2018 11:52 AM
Did you port your number into PM?
Here's how to correctly ask a moderator.
If this solves your question, please select my reply as Solution!
08-18-2018 11:50 AM
@RJW90, I know this is not what you want to hear, but Public Mobile's service model is 100% on-line. General help through this community, and account issues using private messages with moderator team.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
