Samsung Galaxy S20+ MMS issue
07-03-2020 10:17 AM - edited 01-05-2022 11:57 AM
Hello just got this phone i set up the APN no problem but i have my data turned off while on wifi and it wont allow me to receive or send multi media messages any suggestions to fix this?
Phones
07-03-2020 03:01 PM
In order to send and receive MMS, you must turn data on. Even if you are on wifi, data must be enabled.
07-03-2020 12:33 PM
@Andrewbs I think Samsung was supposed to support "rcs(rich communication services)" check your messaging app to opt-in forthis option and you will be able to send and receive MMS through wifi. it's not really MMS more like Imessage
07-03-2020 11:38 AM
@Andrewbs Check your phone settings to see if there is a MMS specific setting that will automatically turn on data when sending/receiving MMS. Otherwise data must be on for MMS to work.
07-03-2020 10:59 AM - edited 07-03-2020 11:00 AM
MMS uses data but that data is not counted toward your paid allowance.
07-03-2020 10:21 AM
You will need to turn on data for MMS messages to work. MMS message does not work on Wifi alone from my understanding. MMS messaging does not use up your data allotment though.
07-03-2020 10:20 AM
You need to turn on data in order to send MMS even though it does not use your data.
07-03-2020 10:20 AM
@Andrewbs wrote:Hello just got this phone i set up the APN no problem but i have my data turned off while on wifi and it wont allow me to receive or send multi media messages any suggestions to fix this?
But data needs to be on to send/receive MMS.
My Samsung S7 seems to have a setting that flips in and out automatically.
