2 weeks ago
does Samsung Galaxy S10+ works ? model sm-g975w
2 weeks ago - last edited 2 weeks ago
From your AI research, the last line said it all: VoLTE guaranteed: NOT always (carrier-dependent)
In this case, PM maintains it own VoLTE whitelist. Generally, it prefers phones designed and sold in North American as well as more recent models. Phones targeted for overseas markets (Europe and Asiaz etc) or older phones that are 4+ years old generally are not compatible.
Again, as said above, with Samsung, you need a S22 or newer model to be compatible with PM network
2 weeks ago
why ? it has LTE option
Short answer: Yes, but it depends on your carrier.
1. Your phone (SM-G975W)👉 That means:
✅ In most cases:
⚠️ But:
Go to:
Settings → Connections → Mobile networks
Look for:
If it’s missing → likely carrier restriction.
Sorry @nijoynn , while Galaxy S10+ has VoLTE, it is not compatible with PM's VoLTE network. You need a newer phone or you will lost your voice services. If you are staying with Samsung, you will need at least a S22 or newer model to be compatible with PM network
As the S10 is now 7 years old and no longer has OS or security updates from Samsung, getting a newer device is highly recommended to avoid potential security vulnerabilities.
