SUBSCRIPTION ACTIVATION FAILED
JOYCE41
need help with completing subscription setup failed on the last step got error code M.8701 on retry
7 REPLIES 7
JOYCE41
Thanks everyone for your input, I set this aside for a couple of days. I will respond to all questions in one post.
The attempt to sign up was done on the app (Iphone 6 Plus) Got all the way to step 6 then got the error msg "SUBSCRIPTION ACTIVATION FAILED" Payment was completed and shows on credit card. Restarted the process including payment and same thing happened, another charge on the credit card.
I am using a physical SIM. Also the number porting was not done in those steps so the phone is still working on Kudo
I will take your advice and follow the link to open a ticket. Thanks again for your time.
@JOYCE41
If your phone indicates Public Mobile and phone is working and charged for service. Don't reactivate SIM again or you will be charged again on your CC. Double check is charges on your CC account has been charged.
HI @JOYCE41
yes, you passed the payment step already
@Cheryl9 had the same error couple days ago, maybe she can share how she got it resolved
https://productioncommunity.publicmobile.ca/t5/Get-Support/Error-code-M-8701-account-configuration-e...
in the meantime,  please submit a ticket with CS Agent here:
Hi @JOYCE41
It seems this error has come up before in the last few days for another member. Reach out to a CS Agent to inform them
To contact a Customer Service Agent, please click on the following link.
Please be sure to keep an eye on the top right corner where you’ll see this icon show up.
HI @JOYCE41
if i am correct, you got the error AFTER the payment step?  PM should have charged you.  And did it also say Configuration error or so?  Are you using eSIM or physical sim card?
If physical try to see if it connects to PM network, which I doubt
you very likely need to open ticket with PM support and have them to investigate further
JOYCE41
thanks for your help....got the error message on step 6 using the app
HI @JOYCE41
you were using the app and you got the error on Step 6?. or you got the error at the payment step?
and check your credit card to see if PM charged yet
