3 hours ago
We had SMS to foward messages to our email and now we c an't seem to get SMS on messages app on A03s. I can't tell from our Usage on our account if we've run out? I've cleared the Cache but otherwise am at a loss. It sends as MMS and we never receive it in our email.
3 hours ago
so, basically is sending out MMS no longer working. Try delete the current APN profile. Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
3 hours ago
SMS are unlimited so you cannot 'run out of it'. You could run out of data if you use 3rd party app to handle SMS/MMS for you.
