08-07-2020 05:31 PM - edited 01-05-2022 12:43 PM
Lately, maybe the last week or so, I've had intermittent issues sending and receiving SMS. Perhaps it's gone on longer and I didn't notice.
Most of the texts I send seem to be sent immediately. Some, maybe 10% ??? seem to take seconds or even a minute or two to send.
Most of the texts I receive seem to come in immediately, more or less. A small number though have come in minutes or even hours later. And one or two out of order. E.g., someone sends me text1, text2, text3, I receive text1 and text3 immediately and much later text2. If it matters, I noticed this in a group chat that I've had active for many months at least and otherwise not had any issues with.
One noteable piece, I got a new phone about 3w ago that otherwise is working well - a Realme 6 pro. Could it be the phone?
Any help greatly appreciated.
08-08-2020 01:51 AM
@ReillyWood This could be network congestion. See if LTE network is enabled. Sending text could have less latency.
08-07-2020 08:25 PM
Turn airplane mode on. Wait 1 min. Turn airplane mode off. This will establish a new (and likely much better)connection with the network. It should solve your issue.
08-07-2020 07:58 PM
Global.
08-07-2020 07:50 PM
@ReillyWood Is your Realme 6 pro the global version or the Indian version? If it's the Indian version that could be a possibility.
08-07-2020 06:40 PM
@ReillyWood a smartphone is essentially a mini computer. Periodic restarts etc and cleaning helps to keep it at peak performance. Stay safe.
08-07-2020 06:37 PM - edited 08-07-2020 06:38 PM
@ReillyWood it would most likely be a network issue. make a note on how your signal is on your phone when these issues occur because it could be as simple as not having good reception causing the delays in text.
when I was in a low signal area at the time my texts sent weren't received till the next day and vice versa
contact customer support here to reset your network on their side
make sure to check your inbox(top right corner envelope icon) periodically, for a response
08-07-2020 06:32 PM
Thanks to both for the suggestions. I'll give the restart a try first, then the network reset if the restart doesn't seem to improve things.
If the above don't work, is there a "procedure" to debug this kind of issue? I imagine it could be my phone or the network or even the sender's phone; how to zero in on the problem?
08-07-2020 05:38 PM
@ReillyWood try resetting your network settings
08-07-2020 05:34 PM
@ReillyWood Try restarting your phone, turn it off, wait 30 seconds and restart it. Stay safe.
