SMS Gateway
Hianodevz
I just tested sending an email to [email protected] and it didn’t go through, so looks like they don’t support email to SMS at this time.
1 REPLY 1
@Hianodevz
Email to Text still works.
Yours didn't go through because you had  the wrong domain. The proper domains should be:
**yes, we need to use Telus or Koodo domain and not Public Mobile
SMS Domain:
     @msg.telusmobility.com
@msg.telus.com
@msg.koodomobile.com
MMS Domain:
@mms.mb.telus.com
@mms.koodomobile.com
@mms.telusmobility.com
Also, please note that only Plain Text format, not HTML, email can send through.  If you are using desktop mail client, most of them are defaulted to Send as HTML, so you have to change it back to Send as Plain Text.  Or if you use Gmail app or via browser, make sure they are send as plain text
