SIMM card
marie_sam1964
How do I activate my SIMM card?
DDM69
A search bar is provided on the page for these types of things. You’ll find many answers with lots of helpful tips. Search “how to activate a sim card”
https://www.publicmobile.ca/en/on/get-help/articles
Chalupa_Batman
Hi @marie_sam1964
You can sign up at public mobile, open an account, pick which plan you'd like, then enter your credit card info and all required info to get started. It will ask what the SIM card number is. Once everything is set, you can place the SIM card into your phone and then reboot it. From there, you should be able to start making calls and texts.
@marie_sam1964 Do it in the nee PM app
