02-25-2022 10:22 AM
Hi, I ordered a sim card on Feb. 11. I have NOT received it yet!!!!!!!
Service
02-25-2022 01:17 PM
PM SIM delivery time is now more reasonable. Don't think it is slow like before. But again, it could be lost.
02-25-2022 12:55 PM
Unfortunately, PM ships SIM cards out by snail mail. Depending on your location it should be arriving soon but contact a CS_Agent and inquire about it.
02-25-2022 11:48 AM
If you have received the order placed email then reply to that email to get the status.
Or open a ticket here by clicking the blurb on the bottom right or by sending a direct msg to CS_Agent.
02-25-2022 11:28 AM
It usually takes 2 weeks or about to receive SIM from PM. But it might take longer due to not enough staff to handle requests. Plus Canada Post is slow these days...
02-25-2022 10:25 AM
HI @Azade Yes, PM used to send SIM very slow. But lately, they have speed it up and customers usually get it within a week.
Open ticket with PM Support and have them investigate or resend you one
Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- Type: did not receive my sim card
- Then click "Contact Us" ,
- and then click "Click here to submit a ticket"
- you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
02-25-2022 10:23 AM
@Azade Generally takes 2 to 3 weeks to receive. Have you received an order processed email at all?
You should reach out to support.
Contact customer service agents.
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
