02-25-2022 10:30 AM - last edited on 02-26-2022 12:16 AM by computergeek541
02-25-2022 12:59 PM
What model iPhone do you have?
If you are near an Apple Genius Care Centre, they can do a quick diagnostic on the phone.
02-25-2022 12:21 PM
HI @Yummy Yes, Apple likes to take care of everything
With iPhone, they cannot really change the APN, it's the Carrier Profile , but it got pushed down. Usually wirelessly is good but I heard some people have difficulty with it and hence needs iTune
Yes, I rather Android. But for people who wants "peace of mind", it's either work or not work, when not work, they head over to Apple stores for support. That was the "cool" way visioned by Jobs 😞
02-25-2022 12:11 PM
@hTideGnow wrote:
@smontic wrote:My iphone 11 is now in 15.3.1 data are still not working
Hi @smontic Make sure your Carrier Profile is the latest one. If not, either pull it wirelessly or use iTune
Is this all necessary (profile, itune, etc.) in order for iphone to work properly? Why so complicated. Still believe Android is most versatile and easiest to use particularly phones from 'big brands' (not alibaba stuff).
02-25-2022 11:33 AM
02-25-2022 11:20 AM
Can you do a full power off restart. Of course you turn on the cellular data, right 🙂 . And if you look on your self-serve overview page does it show a data line under My Data & Add-ons?
02-25-2022 11:17 AM
02-25-2022 11:10 AM
First time with public mobile the sim card was activated in wallmart
02-25-2022 11:09 AM
I'm just trying to update the phone to the last version.
I'm waiting for the end of the procedure.
Is a new simcard sms are working fine. Only data are not working
02-25-2022 10:47 AM
@smontic So you were previously with Public Mobile and for some reason decided to get a new sim card? If so, did you log into account and click "Change Sim card" to attach the sim number to your account?
Are calls n text working?
02-25-2022 10:41 AM - edited 02-25-2022 11:02 AM
If you have the 15.4 beta then make sure you have the most recent version. There was an update.
Edit: And what about calls in/out? Texts in/out?
