04-26-2022
05:21 PM
04-26-2022
05:49 PM
computergeek541
Hello,
I had just activated my SIM card and have just installed it in my phone. But when I had installed the SIM, it says that "SIM not supported" and that it is from a carrier that is not supported under the activation policy. Also stating that, I would need to get my phone to be unlocked by my carrier. My current phone brand is apple, and the model is 6s. I would like to know how I would have solve this problem, and where do I need to go to get it unlocked.
Thank you.
04-26-2022 08:39 PM
Check your iPhone setting by going to: Settings>General>About>scroll down to Carrier Lock>it may have the carrier name.
If it shows No SIM Restrictions then it is unlocked.
04-26-2022 07:24 PM - edited 04-26-2022 07:42 PM
Most likely your phone is locked to previous provider. They should do that by law. But you might find resistance (particularly from Rogers) if you closed account longer than 1 year. But be persistent and threaten if needed to report them to CRTC CCTS.
04-26-2022 06:31 PM - edited 04-26-2022 06:33 PM
@JL9 wrote:The previous provider has to give you the code to unlock it, can't hold that over you.
There's no such thing as an unlock code for an iPhone 6s. Locked/unlocked status is as per an Apple list.
04-26-2022 06:11 PM
I can try to get you one
04-26-2022 06:11 PM - edited 04-26-2022 06:12 PM
@devrajking1314 wrote:Ask your previous provider to give you unlock code. Its free and also if you can tell which provider it was I can get you one
HI @devrajking1314 you have access to unlock codes ?
04-26-2022 06:04 PM
04-26-2022 05:33 PM
04-26-2022 05:23 PM
@User191 - Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
Or, if you purchased this from someone, can you ask them to have the provider it was last with to unlock the phone?
