SIM card
Starr2
When I try to change my SIM card number I enter it then when I hit save it won't save or change.
@Starr2   if you don't have a laptop , you will need PM support to help to make change to the Sim card on your account.  Please open a ticket with them
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
Starr2
I don't have a laptop.
And what is incognito mode?
hairbag1
@Starr2
log in to your account on a laptop but use incognito mode...
dust2dust
Were you doing that on a non-mobile browser? If not, do.
