SIM card
agdixon
I subscribed with eSIM but had to purchase a physical card. I am unable to complete my set up
13 REPLIES 13
Hi @SanjDeva $10 is regular price and Telus store is only helping out with PM
but get it from. Amazon for $5
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
SanjDeva
Went to Telus store for a SIM card, was told $10 and online says $5. What is going on?
Signed up online over 1.5 hrs back, still waiting for activation. Stranded!!!!!!!
@agdixon  you should get reply in 1-3 hours sometimes longer but
agdixon
Already did that thanks
you need PM to help.  You need to submit ticket, but you cannot submit via Chatbot, so just message them using think link
@agdixon  Yes I am , I’m just customer like you trying to help use this link to get help from support to finish your activation
send  a  private message   To CS_Agent
agdixon
Are you there?
agdixon
I have the app installed it is stalled at eht Welcome back Audrey Dixon. let's complete your activation. when I click on the continue buttone it takes me to the eSIM page
@agdixon  .you may need to uninstall the app and reinstall it , but you will need support help to sim swap to the number to your new physical sim if you already tried the eSIM to finish the activation
agdixon
page is stuck on activate subscription for the eSIM
eddieO
@agdixon For the eSIM refund you will need to contact a customer support agent since you have purchased a physical SIM. Can you tell us exactly how far you made it through before getting stuck? Have you installed the Public Mobile app on your phone and tried to complete your account activation through the app?
@agdixon  Support can help change from eSIM  to physical SIM for you , so you can complete your activation using the app remember not website
