SIM card order
Amparo
Hi.
There is an order for a new SIM card, but I didn't order it? How do I cancel? Order 305311
Hi @Amparoook like you are not the only one got the email.  If you don't see a charge on yiue credit card  I think it is safe to just ignore it.  Look like another IT screw up.
dabr
@Amparo   You can ignore it as there appears to be a system glitch sending out errant emails about SIM card orders, unless you are seeing any charges on your payment card?
RossN
@Amparo
hi this is the newest glitch with Public if your cc was charged  you need the help of a cs agent to inquire and ask for a refund
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
